21.12.2012, 19:11 | #1 |
emeadaxsupport: Dynamics AX 2012: A common misconception about Commodity Codes
Источник: http://blogs.msdn.com/b/axsupport/ar...ity-codes.aspx
============== Introduction Commodity codes is one of the many areas in which functionality has changed a bit compared to earlier versions of Dynamics AX. As such, it is only natural that some questions and doubts arise. The purpose of this blog article is to shed some light on some of the changes to this functionality that we have found is often misunderstood in AX 2012. The commodity field is not populating in the sales order line details We have had cases that report that when a user populates the Commodity field on an item (under the Foreign trade fast-tab) and then creates a sales/purchase order, the commodity field on the order line details is not being populated: This has turned out to be a common misconception regarding the usage of the commodity code field on the SO/PO line. This field was introduced in AX 2012 to support line items based purely on Sales or Procurement categories, and not items. If a line item is based purely on Sales or Procurement categories, the field is open for entry and the user may key in the appropriate commodity code manually. In case of line items being item based, AX will take the commodity code directly from the item when filling Intrastat transactions. The sales/purchase order lines are not involved in this process. As such, there is no defaulting of the commodity code onto the order line. FAQ Q: Sales and Procurement categories were introduced in AX 2012. That being said, how was the commodity code used in AX 2009, given that Sales and Procurement categories did not exist? - As you correctly point out, in AX 2009, Sales and Procurement categories do not exist. In this case, the commodity codes are fetched directly from each item. The codes are therefore specified in each individual item. The code that is attached to each item can be viewed at Basic > Periodic > Foreign trade > Intrastat. In AX 2012 however, we have two scenarios: Items and categories.
- Yes. If an item is linked to a specific category and you then create a SO or PO, the order will use the commodity code of the item and not let you choose a commodity code for the category in the order itself. The Commodity field will appear blank and AX will fetch the code directly from the item when filling Intrastat transactions. Thanks for your attention! Eric Vester Support Engineer Microsoft Dynamics AX, SCM CSS/EMEA Источник: http://blogs.msdn.com/b/axsupport/ar...ity-codes.aspx
