Старый 23.03.2017, 11:11   #1
25,475 / 846 (79) +++++++
Filter OData entity by enum field.
Источник: https://ievgensaxblog.wordpress.com/...by-enum-field/
As you may know, logic apps do not have any triggers available for Dynamics365 for Operations. So we have to use recurrence trigger to read data periodically from a data entity and obviously we want to filter a query. This is pretty straightforward with string or integer fields, but not with enums.  Under the hood AX enums are enumeration in OData.
For example, I have new entity “RentalInvoices” and I want to filter it by AXCRMTransferStatus field and select only “pending” records.
Designer view:
Code view:
german_nav_developer: Upgrade Tips & Tricks Teil 3 Blog bot NAV: Blogs 0 17.03.2017 13:11
dynamicsaxhints: How to add enum filter with All element Blog bot DAX Blogs 0 19.07.2016 20:11
dynamicsaxhints: How to make enum a mandatory field on a table Blog bot DAX Blogs 0 04.05.2016 06:17
Часовой пояс GMT +3, время: 03:36.
