Старый 05.01.2018, 22:23   #1
25,475 / 846 (79) +++++++
powerobjects: Microsoft Dynamics 365 Tracking Tokens Enabled
Источник: https://www.powerobjects.com/2018/01...okens-enabled/
Microsoft Dynamics 365 gives you the ability to use tracking tokens to improve the email message tracking capability. A tracking token is an alphanumeric string of characters generated by Dynamics 365 and added to the subject line of an email. Tracking tokens can be turned on or off globally in System Settings under the Email tab. But what if your organization has tracking tokens turned on, but you need to send the occasional one-off email without a tracking token?
The following steps will show you how to send specific emails without a tracking token by first creating an email in draft mode, and then using an on-demand workflow to send that specific email.
Step 1: Create an on-demand workflow. We will need to do two things in the workflow: one is to change the field “no of delivery attempts,” and then one more step to change the status to “pending send.”
  • Update Record: Email
  • Set Properties:
    • No of Delivery Attempts: set to 0
  • Change Record: Email
    • Pending send
Step 2: Create and Send email without a Tracking token:
  • Create an Email and save it in Draft Mode
  • From the draft email click on the ellipses
  • Select Run workflow
  • Select the workflow to remove tracking token
  • Select Add
  • Select OK in the Confirm Application Workflow window
Now your email is set for delivery and the tracking token will not be appended! For more helpful Dynamics 365 tips – check out our blog!
Happy Dynamics 365’ing!
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
NAV Team: Validating Single Sign-on with Office 365 and Microsoft Dynamics NAV 2013 R2 Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:00
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 11 Blog bot Dynamics CRM: Blogs 0 06.10.2012 05:27
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 27.03.2012 02:11
Часовой пояс GMT +3, время: 10:04.
