Старый 06.08.2018, 04:30   #1
25,475 / 846 (79) +++++++
waldo: List all NAV Docker Image Tags on Docker Hub
Источник: https://dynamicsuser.net/nav/b/waldo...-on-docker-hub
Some time ago, I created this script because I wanted to know all the available tags on dockerhub for the “microsoft/dynamics-nav” repository on Docker.
Why? I don’t know anymore :-). But it was clear that the “tags” section on DockerHub only showed us a very small part of the available tags.
Yesterday, we were wondering why a specific version (one that we used quite some time ago from an insider version) wouldn’t download – and we wanted to have a version ‘as close as possible’ to the one we were using. Well – we need a list for that ;-).
PowerShell
You might not be surprised I used PowerShell for that – however I might as well used AL for it. It’s a simple web service-call with a JSON-response. So, it’s quite easy.
Here is the script:
$ResultingObject = @() $result = Invoke-WebRequest -Uri "https://registry.hub.docker.com/v2/repositories/microsoft/dynamics-nav/tags/" $JsonObject = ConvertFrom-Json -InputObject $result.Content $ResultingObject = $JsonObject.results $ParentId = 1 while ($JsonObject.next) { $result = Invoke-WebRequest -Uri $JsonObject.next $JsonObject = ConvertFrom-Json -InputObject $result.Content $ResultingObject += $JsonObject.results $percCompleted = [Math]::Round($ResultingObject.Count / $JsonObject.count, 4) * 100 Write-Progress -Activity "Processing tags" -PercentComplete $percCompleted -ParentId $ParentId }The result is in the “ResultingObject” variable. So you can just query that JSON Array. Here are a few examples:
Display the number of tags:
Display all tags:
$ResultingObject.name
All Belgian tags:
$ResultingObject | where name -like ‘*be’ | select name
Search for a certain version:
$ResultingObject | where name -like ‘*11.0.21063*’ | select name
Enjoy!
Nav developer: Overview of NAV blogs in 2008 Blog bot Dynamics CRM: Blogs 0 07.12.2008 02:18
Часовой пояс GMT +3, время: 03:35.
