Старый 07.06.2018, 03:25   #1
25,475 / 846 (79) +++++++
Extensions and Edit and Display methods declaration in D365
Источник: http://alexvoy.blogspot.com/2018/06/...y-methods.html
Just a short note for my current PU.
Display methods work well as instance methods from table extensions. As to edit-methods, we still need to declare them as static.
[ExtensionOf(tableStr(ProjProposalJour))]
final class avrProjProposalJourTable_ProjInvReport_Extension
static public server edit avrProjInvReportFmtDescWithBr avrEditInvReportFormatWithBR(ProjProposalJour _this, boolean _set, PrintMgmtReportFormatDescription _newReportFormat)
PrintMgmtReportFormatDescription newReportFormat = _newReportFormat;
PrintMgmtReportFormatDescription reportFormat;
reportFormat = ProjInvoicePrintMgmt::avrGetReportFormatWithBR(_this);
if (_set)
if (_this.RecId && newReportFormat && newReportFormat != reportFormat)
ProjInvoicePrintMgmt::avrCreateOrUpdateInvoiceWithBRPrintSettings(_this, PrintMgmtNodeType::ProjProposalJour, newReportFormat);
reportFormat = newReportFormat;
return reportFormat;
Do not forget to pass the table buffer as the first argument.
More detail can be found in Vania's article about news in PU11.
Kashperuk Ivan: Development Tutorial: Extensibility: Adding a table display/edit method and showing it on a form in PU10 Blog bot DAX Blogs 20 07.10.2017 12:42
sertandev: AX7 Extensibility Overview – Part 2 : Code extensions Blog bot DAX Blogs 0 28.08.2017 19:11
Часовой пояс GMT +3, время: 12:59.
