Старый 11.02.2017, 01:11   #1
25,475 / 846 (79) +++++++
jaestevan: Why you should be using Team Foundation Server for Dynamics AX lifecycle management?
Источник: http://www.jaestevan.com/why-you-sho...cle-management
If you already use Team Foundation Server in your Dynamics AX projects, providing all benefits it can give to your teams, or if you are already convinced to use it soon, then this article is not for you.
You may not be convinced or, even worst, you may disagree about it to be beneficial to your methodologies and team behaviors. You can try to challenge my points with your project’s circumstances that make TFS unacceptable. That’s fine. I’m only asking you to read the full article first
Team Foundation Server (or Visual Studio Team Services*) is a tool, and as such, it will allow you to achieve the same tasks faster and with less effort. Furthermore, TFS will also give the ability to execute crucial tasks that are only available by using this kind of tools. Those tasks are mostly related to development work and source code management, what makes developer’s life easier, but some of them also help project managers and consultants, and support Quality Assurance guidance and validations, testing and all the rest of Application Lifecycle Management steps, whichever methodology is used to manage our projects: Microsoft SureStep, Agile, Scrum, …
Not to mention that using TFS is mandatory in the new Dynamics 365 for Operations, so including it in our lifecycle processes today will ease the transition and will put in place a set of Best Practices than will improve your team since day one.
Let’s have a look at the benefits of TFS in the three main categories of Application Lifecycle Management:
  1. Work
  2. Code
  3. Build & Release
Read the full article at “Dynamics AX in the Field”, the blog from the Premier Field Engineering team at Microsoft.
jaestevan: PowerShell para la administración automática de Dynamics AX 2012 (PS-II) Blog bot DAX Blogs 0 28.06.2016 17:11
instructorbrandon: The Dynamics AX Architect’s Guide to Team Foundation Server Part 1 Blog bot DAX Blogs 0 07.12.2015 07:15
daxdilip: Announcing support for Team Foundation Server 2015 with AX 2012 R2 and R3 Blog bot DAX Blogs 0 30.11.2015 22:11
Dynamics AX Sustained Engineering: Announcing Support for SQL Server, SharePoint, and Office 2013 Service Packs as well as Visual Studio Team Foundation Server and Visual Studio Online Blog bot DAX Blogs 0 09.10.2014 23:11
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
Часовой пояс GMT +3, время: 12:54.
