Старый 26.03.2019, 04:15   #1
25,475 / 846 (79) +++++++
crmtipoftheday: Tip #1240: Trigger another entity’s flows
Источник: https://crmtipoftheday.com/1240/trig...entitys-flows/
I have a flow on Account, and sometimes I want to trigger that flow to run when a related contact is updated. Given we don’t have child Flows yet, how can I make a change to one record execute a flow on a different entity?
One trick that I’ve used on workflow that is also a solution for Flow is to update one of the fields that triggers the flow on the parent record. If you don’t want to change the value of the record, you can update the field with its current value.
This will trigger the flow to be run.
crmtipoftheday: Tip #1221: Need entity permission for dynamics lookup filters Blog bot Dynamics CRM: Blogs 0 15.02.2019 17:11
crmtipoftheday: Tip #1207: Check applied entity permissions in portals Blog bot Dynamics CRM: Blogs 0 10.12.2018 17:11
crmtipoftheday: Tip #1149: Create custom schedule for your flows Blog bot Dynamics CRM: Blogs 0 10.08.2018 19:11
crmtipoftheday: Tip #1044: Display lookups as hyperlinks in portal entity list Blog bot Dynamics CRM: Blogs 0 15.12.2017 03:21
crmtipoftheday: Tip #1024: Make an entity regarding available from Outlook App Blog bot Dynamics CRM: Blogs 0 16.11.2017 20:11
Часовой пояс GMT +3, время: 21:18.
