16.01.2021, 03:41 | #1 |
How to delete obsolete values in ENUMVALUETABLE table X++
Источник: http://alexvoy.blogspot.com/2021/01/...values-in.html
============== Following up this old issue with extensions to enums, I propose to run this class, if you cannot delete added values (CDP* in my case) directly in SQL Studio. I am not sure if it is going to work in PROD. Please use it at your own risk. class CDPENUMVALUETABLEDelete { public static void main(Args _args) { if(!Box::confirm("Would you like to delete all CDP* values of SysPolicyRuleTypeEnum type in ENUMVALUETABLE? (If not, just print them")) { CDPENUMVALUETABLEDelete::printRecords(); return; } CDPENUMVALUETABLEDelete::deleteRecords(); info("all related records have been deleted. Synchonize DB now!"); } private static void deleteRecords() { Connection conn; SqlStatementExecutePermission permission; str sqlSelect = @"SELECT t.RECID from ENUMVALUETABLE as t join ENUMIDTABLE on enumid = id and ENUMIDTABLE.NAME = 'SysPolicyRuleTypeEnum' and t.NAME like 'CDP%'"; str sqlDelete = strFmt("%1 (%2)", "DELETE FROM ENUMVALUETABLE WHERE RECID IN ", sqlSelect); permission = new SqlStatementExecutePermission(sqlDelete); conn = new Connection(); permission.assert(); //conn.transactionScopeBegin(); Statement statement = conn.createStatement(); int result = statement.executeUpdate(sqlDelete); str errText = statement.getLastErrorText(); if(errText) { Info(errText); } // the permissions needs to be reverted back to original condition. CodeAccessPermission::revertAssert(); } private static void printRecords() { Connection conn; SqlStatementExecutePermission permission; str sqlSelect = @"SELECT t.RECID, t.ENUMID, t.ENUMVALUE, t.NAME from ENUMVALUETABLE as t join ENUMIDTABLE on enumid = id and ENUMIDTABLE.NAME = 'SysPolicyRuleTypeEnum' and t.NAME like 'CDP%'"; permission = new SqlStatementExecutePermission(sqlSelect); conn = new Connection(); permission.assert(); Statement statement = conn.createStatement(); ResultSet results = statement.executeQuery(sqlSelect); str errText = statement.getLastErrorText(); if(errText) { Info(errText); } int enumId; str name; int i = 1; while (results.next()) { enumId = results.getInt(3); name = results.getString(4); Info(strFmt("Found %1) %2 : %3", i, enumId, name)); i++; } // the permissions needs to be reverted back to original condition. CodeAccessPermission::revertAssert(); } } Do not forget to build your models and full DB sync after! Источник: http://alexvoy.blogspot.com/2021/01/...values-in.html
Опции темы | Поиск в этой теме |
Опции просмотра | |
