Старый 14.09.2017, 13:11   #1
25,475 / 846 (79) +++++++
dynamicsnavax: Table casting in AX 2012 and D365O
Источник: http://dynamicsnavax.blogspot.com/20...and-d365o.html
D365O is a lot more sensitive about casting or should I say AX2012 was too relaxed about it. This post is to show a specific scenario that works differently in the new version of the product.
We had a bit of code that worked fine in AX2012 but stopped working in D365O. After debugging we found that when you cast a table it took the tableId of the cast.
Below is an example of AX2012 vs D365O:
UPDATE – Thanks for Joris for pointing this out.
Same code running in CIL in AX2012. The piece of code in question was running client side. Otherwise, I would have noticed this in AX2012 too.
ievgensaxblog: D365O. Trick to pass a value between Pre and Post event handler using XppPrePostArgs. Blog bot DAX Blogs 0 01.07.2017 10:13
Retail Peripheral Simulator для D365O gl00mie DAX: Функционал 6 07.02.2017 18:00
Часовой пояс GMT +3, время: 07:07.
