Старый 17.03.2017, 13:11   #1
25,475 / 846 (79) +++++++
dynaxtips: Master planning in Manufacturing
Источник: https://dynaxtips.com/2017/03/17/mas...manufacturing/
I just got my copy of the new Scott Hamilton book! Look at how happy I am!
It is an in-depth master piece that covers all the functionality from the basics to the advanced. Organized and written in a way that everyone with basic knowledge of the subject matter and ERP can digest it. It covers all the different type of manufacturing scenarios (Discrete, Project, Process and Lean) and has a great deal of case studies that are informative and might even solve many of your known and unknown issues.
This is the go-to book for any company that is using Master planning functionality. If you’re a customer, user or partner of Dynamics AX2012 or Dynamics 365 for Operations, then you should go get this book ASAP. You’ll probably save the cost after the second chapter (As the first is the introduction)…
It will deepen the understanding of the features for people that are already up and running on the system as well as work as a reference guide. And it is a great companion and a must-read to people doing an implementation or want to simply learn the solution.
Go get your copy either physical or electronically now!
https://www.amazon.com/dp/099730717X
Also read some of Scotts latest posts on MSDynamicsWorld.com for more info:
Filed under: AX 2012, AX7, Manufacturing
dynaxtips: Dynamics Podcast // Episode 5 // Community and Master planning Blog bot DAX Blogs 0 22.12.2016 15:11
organicax: Master Planning parameters – Find purchase agreements Blog bot DAX Blogs 0 16.09.2016 19:13
organicax: Intercompany master planning. Blog bot DAX Blogs 0 03.04.2016 08:23
kurthatlevik: Master data concepts Blog bot DAX Blogs 0 18.02.2016 12:11
dynamics-community.at: Neue Trainingsunterlagen für Dynamics AX 2012: Intercompany Setup and Order Processing / Master Planning Blog bot DAX auf Deutsch 0 09.03.2012 14:11
Часовой пояс GMT +3, время: 05:41.
