Старый 02.03.2018, 06:16   #1
25,475 / 846 (79) +++++++
AX 2012 R3 CU13 Bug: DMF default value mapping for String type
Источник: http://alexvoy.blogspot.com/2018/03/...ult-value.html
There is bug in AX 2012 R3 CU13.
If you check Default type for your data entity staging mapping field of String type, then the system tries to find any first record matching to "Default" value as XML name to get the linked field and compare against its string length.
To fix it, we need to make the following changes in three methods of the form DMFStagingDefaultTable
public class FormRun extends ObjectRun
SysDictField dictField;
DMFFieldType dmfFieldType;
DMFSourceXMLToEntityMap dmfSourceXMLToEntityMap;
Types valueType;
// Begin: Alexey Voytsekhovskiy
int wblMaxStrSize;
// End: Alexey Voytsekhovskiy
public void init()
Args args;
DMFEntity entity;
DMFDefinitionGroupEntityXMLFields dmfDefinitionGroupEntityXMLFields;
SysDictType dictType;
#define.Integer('Integer')
#define.String('String')
#define.RealMacro('Real')
#define.DateMacro('Date')
#define.DateTimeMacro('UtcDateTime')
#define.Time('Time')
super();
if (!element.args() || element.args().dataset() != tableNum(DMFSourceXMLToEntityMap))
throw error(strfmt("@SYS25516", element.name()));
args = element.args();
dmfSourceXMLToEntityMap = args.record();
select firstOnly FieldType, FieldSize from dmfDefinitionGroupEntityXMLFields
where dmfDefinitionGroupEntityXMLFields.FieldName == dmfSourceXMLToEntityMap.EntityField
&& dmfDefinitionGroupEntityXMLFields.Entity == dmfSourceXMLToEntityMap.Entity
&& dmfDefinitionGroupEntityXMLFields.DefinitionGroup == dmfSourceXMLToEntityMap.DefinitionGroup
wblMaxStrSize = dmfDefinitionGroupEntityXMLFields.FieldSize ? dmfDefinitionGroupEntityXMLFields.FieldSize : 256;
if (dmfDefinitionGroupEntityXMLFields.FieldType && !dmfSourceXMLToEntityMap.IsAutoDefault)
dmfFieldType = dmfDefinitionGroupEntityXMLFields.FieldType;
if (dmfsourceXMLToEntityMap.EntityField)
entity = DMFEntity::find(dmfsourceXMLToEntityMap.Entity);
dictField = new SysDictField(tableName2id(entity.EntityTable), fieldName2id(tableName2Id(entity.EntityTable),dmfsourceXMLToEntityMap.EntityField));
switch(dmfDefinitionGroupEntityXMLFields.FieldType)
case #Integer:
DMFStagingConversionTable_StagingIntValue.visible(true);
break;
case #String:
DMFStagingConversionTable_StagingStrValue.visible(true);
break;
case #RealMacro:
DMFStagingConversionTable_StagingRealValue.visible(true);
break;
case #DateMacro:
DMFStagingConversionTable_StagingDateValue.visible(true);
break;
case #DateTimeMacro:
DMFStagingConversionTable_StagingUtcDataTime.visible(true);
break;
case #Time:
DMFStagingConversionTable_StagingTimeValue.visible(true);
break;
default:
warning("@DMF694");
element.close();
else if(dmfSourceXMLToEntityMap.IsAutoDefault)
dictField = new SysDictField(tableName2id(entity.EntityTable),fieldName2id(tableName2Id(entity.EntityTable),dmfsourceXMLToEntityMap.EntityField));
dictType = new SysDictType(dictField.typeId());
if (dictType && dictType.isTime())
valueType = Types::Time;
else
valueType = dictField.baseType();
dmfFieldType = enum2str(dictField.baseType());
switch(valueType)
case Types::Integer:
break;
case Types::String:
break;
case Types::Real:
break;
case Types::Date:
break;
case Types::UtcDateTime:
break;
case Types::Time:
break;
case Types::Guid:
DMFStagingConversionTable_StagingGuidValue.visible(true);
break;
default:
warning("@DMF694");
element.close();
else
element.close();
and on the sole form data source field StagingStrValue
public boolean validate()
boolean ret;
ret = super();
if(ret)
if(strLen(DMFStagingConversionTable.StagingStrValue) > wblMaxStrSize)
throw error("@DMF788");
// select firstOnly FieldSize from dmfDefinitionGroupEntityXMLFields
// where dmfDefinitionGroupEntityXMLFields.FieldName == dmfSourceXMLToEntityMap.XMLField;
// if(dmfDefinitionGroupEntityXMLFields.FieldSize)
// if(strLen(DMFStagingConversionTable.StagingStrValue) > dmfDefinitionGroupEntityXMLFields.FieldSize)
// throw error("@DMF788");
return ret;
AX 2012 R3 CU11 upgrade to CU13 January 2018 Release problem oip DAX: Администрирование 3 22.02.2018 20:19
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: Form created in e.g. AX 2012 RTM or AX 2012 R2 with ManagedHost control on its design fails to open on AX 2012 R3 Blog bot DAX Blogs 0 21.09.2015 19:11
Часовой пояс GMT +3, время: 15:19.
