Старый 14.09.2017, 13:11   #1
25,475 / 846 (79) +++++++
domhk: AX2012 - Listing reports which run against AX SSAS Cubes
Источник: http://domhk.blogspot.com/2015/06/ax...which-run.html
Just to share a quick tip. If you need to know which SSRS reports in AX gather data from AX OLAP cubes, you can run the query below in SSMS against the report server database.
SELECT a.Path, a.Name as FullName,
SUBSTRING(a.Name, 1, CHARINDEX('.', a.Name)-1) as ReportName,
SUBSTRING(a.Name, CHARINDEX('.', a.Name)+1, 1000) as DesignName,
a.Parameter, b.Name, b.Extension
FROM Catalog a
JOIN DataSource b
ON a.ItemID = b.ItemID
WHERE b.Name = 'DynamicsAXOLAP'
Order by a.Name, b.Name, a.Path
The result is like this:
There are report name, design name and an XML presentation of the Parameters. The ReportName column contains the name of the reports, which match the nodes under \SSRS Reports\Reports in AOT.
stoneridgesoftware: SSAS Reports and the Cubes that Source the Data Blog bot DAX Blogs 0 21.06.2016 21:13
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
axinthefield: Compatibility Testing for Microsoft Dynamics AX Blog bot DAX Blogs 0 23.06.2012 02:26
emeadaxsupport: Debugging Microsoft Dynamics AX 2009 SSRS reports with Microsoft Visual Studio 2008 Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 20:37.
