Старый 14.09.2017, 13:11   #1
25,475 / 846 (79) +++++++
vsdynamicsfinance: Activate Document handling function for posted journals
Источник: https://vsdynamicsfinance.wordpress....sted-journals/
This article describes how to active the document handling function for posted journal in Dynamics AX 2012. By default, the document handling function is not available once a journal has been posted. But you can activate this function per table. Navigation: Organisation administration > Setup > Document management > Active document table Click Update to […]
emeadaxsupport: Attachment function using Document handling for settled "closed" transaction Blog bot DAX Blogs 0 12.02.2015 22:12
atinkerersnotebook: Creating Your Own Document Management System With SharePoint Blog bot DAX Blogs 0 02.10.2013 21:12
kamalblogs: Dev Tip: Activating document handling for inquiry(read only) forms – Dynamics Ax 2012 Blog bot DAX Blogs 0 20.09.2013 13:11
dax-lessons: Document Handling in AX - setup and Example Blog bot DAX Blogs 0 27.08.2007 23:00
Часовой пояс GMT +3, время: 02:46.
