Старый 05.02.2011, 12:23   #1
25,475 / 846 (79) +++++++
Hi Everybody!
I was playing around with the new RTC over WAN feature in NAV 2009 R2.
Basically I was following the instructions on the MSDN website you can find on http://msdn.microsoft.com/en-us/library/gg502478.aspx
The reason for this is that I want to know HOW it works, and also the performance will be. Of course this is only a hyper v server image running on a test environment you will not have a real performance.
But anyway, for me and I think for a lot of other people this is “good enough”  to evaluate when it could make sense working with it.
Regarding to this points I thought you could be interested in trying it by yourself without installing your own server.
Because of this I will give you my configuration data and credentials and so you are “only” need a RTC to try it by yourself.
But sorry guys – I need the the resources on this machine and that’s the reason why I will turn off this virtual server after 5 days.
1. Download the files
2. Install both certificates (these are test certificates built by HOW TO from MSDN)  (Right mouse click – install certificate – select store automatically)
3. Backup your existing UserSettings.config file.
4. Replace the existing one with the one from your downloaded files
5. Start the RTC
6. Login by using contosoadministrator – pass@word1
Language English and German is available.
Regards,
Rene
PS would be great if you write comments on this post if you get experience with it.
Далее
Часовой пояс GMT +3, время: 07:00.
