Старый 01.04.2017, 02:17   #1
25,475 / 846 (79) +++++++
stoneridgesoftware: Receiving an error ‘_XYZ is an unwanted object name’ when checking in a model for TFS
Источник: https://stoneridgesoftware.com/recei...model-for-tfs/
Symptom:
I am in the process of setting up TFS for my Dynamics AX instance. When checking in my model, I am receiving errors similar to these:
\Project\Shared\_XYZMaterialsManager is an unwanted object name.\Security\Roles\_XYZMaterialsManager is an unwanted object name.
The reason I was getting the above error is because I have a shared project and a security role in my AOT where their names start with ” _XYZ” AND in my Exclude element names in version control system setting I have a record with “ System Settings, then click on Exclude element names (fast link on the left). You will see a record with a value of
stoneridgesoftware: Dynamics 365 for Operations: How to Create a New Model Blog bot DAX Blogs 0 11.02.2017 01:11
stoneridgesoftware: Using X++ to Find if an Object Exists in the Current Model Blog bot DAX Blogs 0 10.02.2017 19:11
stoneridgesoftware: How to prevent the error Failed to Register Service Principal Name (SPN) in Dynamics AX, when not using Kerberos Blog bot DAX Blogs 0 26.05.2016 18:11
Navigate Into Success: Try..Catch for .NET Interoperability Blog bot Dynamics CRM: Blogs 0 29.10.2014 09:00
NAV2009 R2 Web Service для интеграции AS850 NAV: Программирование 2 31.07.2011 21:16
Часовой пояс GMT +3, время: 08:15.
