Старый 07.04.2017, 14:11   #1
25,475 / 846 (79) +++++++
palleagermark: Language issue in AX 2012 with Views built on security tables
Источник: http://www.agermark.com/2017/04/lang...ith-views.html
Some of the security related system/kernel tables in AX 2012, like for example SecurityRole, is backed by Views in the model store.
If you look at the Views in the model store you can see that some fields hold a label id rather than a text. For SecurityRole, the fields Name and Description holds label ids.
Somewhere in the AX kernel these label ids are converted to actual texts according to the language of the user. So inside AX we don't see these labels, but we see the language specific texts.
This is also the case if you create a View where these tables are part of the meta data.
However if you change the language for your user, it doesn't seem like these Views are updated according to the new language. They keep returning data in the previous language, even after restarting the client and AOS. The only way I have found to make it use the new language is to manually synchronize the view from the AOT.
daxserver: Migrating security settings between different Dynamics AX 2012 instances Blog bot DAX Blogs 0 08.05.2013 12:11
daxdilip: Microsoft Dynamics AX 2012 Security Book - A sneak preview Blog bot DAX Blogs 0 20.11.2012 18:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
dynamics-ax: Microsoft Dynamics AX 2012 and the use of Claims Based Security Blog bot DAX Blogs 0 08.03.2011 06:24
Часовой пояс GMT +3, время: 04:02.
