Старый 08.03.2019, 01:23   #1
25,475 / 846 (79) +++++++
axatoz: Using Postman with D365
Источник: https://axatoz.wordpress.com/2019/03...man-with-d365/
We need the right tool for the job. Postman is a tool that often used to interact with Restful services (OData). Below is how you can setup postman to work with D365 (assuming you know how to setup on Azure side like tenant_id, client_id, client_secret)
SETUP
Setting up BearerToken
Params tab
Body tab
grant_type: {{grant_type}}
client_id: {{client_id}}
client_secret: {{client_secret}}
resource: {{resource}}
Test tab
var json = JSON.parse(responseBody);
tests[“Get Azure AD Token”] = !json.error && responseBody !== ” && responseBody !== ‘{}’ && json.access_token !== ”;
postman.setEnvironmentVariable(“bearerToken”, json.access_token);
TEST
OR
Postman with CRUD operations
Insert
Operation
Header tab
Authorization =
Bearer {{bearerToken}}
If-None-Match = null
OData-Version = 4.0
Content-Type = applicatin/json
Accept = application/json
Odata-MaxVersion = 4.0
Body tab
Result
axatoz: D365 Positive Pay File – Wells Fargo Blog bot DAX Blogs 0 08.03.2019 01:23
powerobjects: D365 In Focus: Field Service for Dynamics 365 from D365 University [VIDEO] Blog bot Dynamics CRM: Blogs 0 08.12.2017 03:13
axatoz: LCS – Issue search can’t find other AX versions Blog bot DAX Blogs 0 14.09.2017 13:11
axatoz: Dynamics AX 2012 R3 Report Deployment Error with Visual Studio 2013 Blog bot DAX Blogs 0 14.09.2017 13:11
Часовой пояс GMT +3, время: 05:45.
