Старый 30.04.2020, 12:12   #1
25,475 / 846 (79) +++++++
dynamicsaxinsight: Generate financial report in X++
Источник: https://dynamicsaxinsight.wordpress....l-report-in-x/
Purpose
The purpose of this blog post is to demonstrate how can we generate a financial report in X++ and download it as a file.
Product
Dynamics 365 Finance.
Description
Please find the code snippet below which can be used to generate a financial report in X++. The code generates the report in XML format. The same code can be used to export the report in Excel and XPS file formats. Once generated the code allows the user to download the generated report.
public static void main(Args _args){ financialReportVersion financialReportVersion; FinancialReports financialReports; PeriodEnd periodEndDate; str reportName; str fileContent; const str fileName = 'FinancialReport.xml'; reportName = "12 Month Rolling Single Column Income Statement - Default"; periodEndDate = FiscalCalendarYear::findYearByCalendarDate( Ledger::fiscalCalendar(CompanyInfo::find().RecId), systemDateGet()).EndDate; select firstonly financialReportVersion order by recid desc join financialReports where financialReports.DesignId==financialReportVersion.DesignId && financialReports.reportName == reportName; FinancialReportingIReportExport reportExporter = new FinancialReportingReportExport(); System.Text.Encoding encodingGB18030 = System.Text.Encoding::GetEncoding("utf-8"); if (!financialReports.DesignId) { throw error(strfmt("Design not found for Report %1", reportName)); } System.IO.Stream stream = reportExporter.GenerateAndExportReport( financialReports.DesignId, curExt(), periodEndDate, FinancialReportingReportExportFormat::Xml, encodingGB18030); if (stream == null) { throw error(strfmt("Stream is empty for Report %1 period %2", reportName, periodEndDate)); } System.IO.StreamReader sReader = new System.IO.StreamReader(stream); fileContent = sReader.ReadToEnd(); File::SendStringAsFileToUser(fileContent, fileName);}
NAV Team: Report Execution Insights Blog bot Dynamics CRM: Blogs 0 30.10.2014 15:02
ax-erp: Walkthrough: Creating a Report Bound to a Report Data Provider Class (X++ Business Logic) [AX 2012] Blog bot DAX Blogs 0 20.09.2012 11:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 04:45.
