Старый 03.01.2017, 22:12   #1
20,585 / 712 (65) +++++++
emeadaxsupport: Cannot find a valid offline scope with the name ‘YourTable’ in table ‘[scope_info]’.
Источник: https://blogs.msdn.microsoft.com/axs...le-scope_info/
Credit to Brian Storie for the contribution provided. Symptom Microsoft.Synchronization.Data.DbSyncException: Cannot find a valid scope with the name ‘YourTable’ in table ‘[scope_info]’. Ensure that this scope exists and that it has a corresponding valid configuration in the configuration table ‘[scope_config]’. Cause You have created a new Offline scope, added it to the POS Offline profiles form... Read more
emeadaxsupport: AX Retail Offline Database: Critical Microsoft Sync Framework hotfix required Blog bot DAX Blogs 0 15.01.2015 02:15
emeadaxsupport: Unable to close shift due to records in Offline database Blog bot DAX Blogs 0 20.08.2013 15:11
emeadaxsupport: Cannot copy table SQLDictionary error when Connecting to Source Database during upgrade Blog bot DAX Blogs 0 02.11.2012 23:13
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 00:23.
