Старый 23.09.2018, 13:13   #1
25,475 / 846 (79) +++++++
sinedax: How to suspend RecId Sequence - Dynamics 365 for Finance & Operations
Источник: http://sinedax.blogspot.com/2018/09/...-dynamics.html
Hi,
as you know in D365FO now the sequences are handled by SQL and not anymore from the SYSTEMSEQUENCES table.
From particular scenarios could be necessary to suspend the Recid assignement.
In order to do that, issue the following command:
appl.sysRecIdSequence().suspendRecIds(tableNum(TABLENAME));
Tale a look also to the standard AccountingDistributionProcessor class, SuspenAccDistRecidAssignment method.
Till soon!
sinedax: Fast Deployment - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 07.05.2018 00:15
sinedax: Violation of PRIMARY KEY constraint 'I_65518FIELD' - Dynamics 365 for Finance & Operations LBD Blog bot DAX Blogs 0 06.05.2018 18:13
atinkerersnotebook: Learn how to Create a new Dynamics 365 for Operations Training Environment through Lifecycle Services Blog bot DAX Blogs 0 01.12.2016 18:11
NAV Team: How to: Set up your Microsoft Dynamics NAV installation for Single Sign-on with Office 365 using Windows PowerShell Blog bot Dynamics CRM: Blogs 0 19.12.2013 15:10
Часовой пояс GMT +3, время: 23:59.
