Старый 09.08.2018, 17:11   #1
25,475 / 846 (79) +++++++
d365technext: Passing values between PreHandler & PostHandler
Источник: http://d365technext.blogspot.com/201...rehandler.html
using the below code you can pass the custom value between pre handler and post handler
Example
/// enforcePayRateTolerance pre event hanlder
/// Event args
[PreHandlerFor(tableStr(HRMCompFixedPlanTable), tableMethodStr(HRMCompFixedPlanTable, enforcePayRateTolerance))]
publicstaticvoidHRMCompFixedPlanTable_Pre_enforcePayRateTolerance(XppPrePostArgs args)
args.addArg("Tolerance", "Sheikh Sohail Hussain");
Example
/// enforcePayRateTolerance post event hanlder
/// Event args
[PostHandlerFor(tableStr(HRMCompFixedPlanTable), tableMethodStr(HRMCompFixedPlanTable, enforcePayRateTolerance))]
publicstaticvoidHRMCompFixedPlanTable_Post_enforcePayRateTolerance(XppPrePostArgs args)
if (args.existsArg("Tolerance"))
Info( args.getArg("Tolerance"))
d365technext: Environment Hot-Fixes List Using X++ D365FO & AX 7 Blog bot DAX Blogs 0 02.08.2018 18:12
Channel9 CRM: CRM Passing Values Between Entity Records During Creation Blog bot Dynamics CRM: Blogs 0 19.03.2017 23:13
emeadaxsupport: Passing UtcDateTime values in extended query syntax Blog bot DAX Blogs 0 10.05.2010 21:05
Microsoft Dynamics CRM Team Blog: Quick Tip: Passing CRM Form values to an IFrame Blog bot Dynamics CRM: Blogs 0 12.09.2008 02:05
Issues concerning X++: CLR interop: Passing Int16 values to managed code. Blog bot DAX Blogs 0 03.07.2007 00:31
Часовой пояс GMT +3, время: 23:20.
