Старый 15.04.2017, 19:21   #1
25,475 / 846 (79) +++++++
organicax: Using the Is One Of In the query filter
Источник: https://organicax.com/2017/04/15/usi...-query-filter/
Working in D365 you have a few options for filtering the data. One option is the Is One Of. This will allow you to select different values that you want to include in the filter. There are a few ways to access this one is drop down on the field and select the values, the second is using the advanced query to specify the values with a comma separating the values which would be familiar to users upgrading from AX2012.
Here is a quick overview.
D365 1611 Update5 (7.0.4475.35138)
Cheers
Lachlan
Filed under: User tips
organicax: Using the filter button in the Excel add-in. Blog bot DAX Blogs 0 30.03.2016 01:18
organicax: Advanced filter and sort in the new Dynamics AX Blog bot DAX Blogs 0 08.03.2016 05:55
emeadaxsupport: Microsoft Dynamics AX general performance analysis scripts page 5 Blog bot DAX Blogs 0 01.09.2014 14:11
ax-erp: Pass Query from dialog to Form and Filter records Blog bot DAX Blogs 0 18.09.2012 18:11
Часовой пояс GMT +3, время: 05:34.
