Старый 09.04.2021, 04:41   #1
25,475 / 846 (79) +++++++
kurthatlevik: D365 – CustTable – fast – faster – fastest – WOW!
Источник: https://kurthatlevik.com/2021/04/09/...r-fastest-wow/
I wanted to look deeper into an area that have troubled me for some time. Why are some forms very fast in D365, and some forms do not have the expected start-up time. At the end of this article you can see my finding, and I hope this will have an positive effect on user experienced performance.
The form I wanted to take a deeper look into is the custTable form, as this is one of the most used forms at customers. Over time we have seen that this form has increased in size, by additional features and code being added. New features are great, but it comes at a cost.
I wanted a simple test, where we are looking at a warm system, and time how long time it would take to open the CustTable form. I would like to test the opening of custTable a Cloud Hosted Tier-1 (DS12 V2), Tier-2 and PROD. This is benchmarked with a top-watch, and timing is from I click on menu item, until form is drawn and responsive. I will be using google chrome with F12, and measure until all network, and the main measurement will be TTFB (Time To First byte), as seen in the picture below. The actual waiting time tend to be beyond this, but it is the most concrete KPI I have found. The timing is therefore not the actual or experienced performance, but a KPI that can be used for comparing scenario’s.
The KPI represents the time the AOS/IIS is using to render and return the form object to the browser. Each “warm test” will be conducted 3 times, and the data is an extremely small dataset (just a few customers), as the purpose of this test is NOT to test the database, indexes or queries. It is about testing how the execution of code and caching on a form is performing.
Below is a screenshot showing where to find my performance KPI in the F12 Google chrome developer menu.
Test of architecture
In this test I’m testing how fast the custTable form is opened on Tier1, Tier-2 and on a PROD environment. The PROD/Tier-2 environments are on service fabrics(self-service), and the databases seams to be elastic pool based.
As seen on the table below the fastest execution happens on Tier-1, that is a one-box SQL, and the Tier-2 and PROD
Customer form
Warm execution
Cold execution
Tier-1 (DS12 V2)
1.50, 1.49, 1.49
22.99
Tier-2
2.20, 2.32, 2.20
16.96
Prod (6 AOS’s)
3.22, 3.25, 3.10 (20:00 CET)
2.37, 2.46, 2.40 (22:00 CET)
Not measured
What we here see is that a cold execution of the CustTable form is extreme, with a dramatic increase execution time. What we also see is that PROD differs on execution time. This can be because of different connection to another AOS, or affection of “noisy neighbor” caused by switch to Azure SQL elastic pool architecture.
On a simpler form like the “customer reason code” form, without much code, we see a very nice execution time on all tier-levels, and even cold executions are within acceptable range.
Customer reason code form
Warm execution
Cold execution
Tier-1 (DS12 V2)
0.11, 0.11, 0.12
1.01
Tier-2
0.26, 0.27, 0.26
0.98
Prod (6 AOS’s)
0.27, 0.28, 0.23
Not measured
The conclusion seams that complex forms, as the custTable are much more affected when opening a form in a cold state.
The complexity of the CustTable
As seen below, the CustTable contains 12 datasources, and quite many of them are joins. There are also 4 extension to the form.
We also see in the code in the CustTable is heavily regulated by code that controls features, country specific/regulatory elements, and display items. If we open the Customer form on a Tier-2 environment with 5 customers takes between 2-3s. In total there are 16.413 method calls, and of them 1.330 are unique method calls.
I did not get any meaningful information out of the recorded summarized tracefile analysis, so I must continue to more manually look into the actual execution of code.
Test of effect when reducing complexity CustTable
My next step in the analysis is to see what is affecting the execution time. In the following section I’m testing in a Tier-1 D12V2 environment. I have made 5 copies of the CustTable form, in each form, I’m removing more and more code and data sources. I name them:
  1. Standard, but no calls to feature enablement
  2. Fast : All code and data datasources removed, except custTable and DirParty
  3. Faster : All code and data datasources removed, except custTable. Display method on customer name
  4. Fastest; All code is removed except CustTable data source
To simulate a “cold execution” we can flush the cache by adding the following to the URL: &mi=ACTION%3ASysFlushAOD
CustTable form type
Warm execution (s)
Cold execution (s)
Standard 10.0.18
1.50, 1.49, 1.49
22.99
1.Standard, but no calls to feature enablement code
1.34, 1.43, 1,39
17.94
2.Fast : All code and data datasources removed, except custTable and DirParty
0.72, 0.72, 0.73
1.22
3.Faster : All code and data datasources removed, except custTable. Display method on customer name
0.56, 0.62, 0.57
0.96
4.Fastest; All is removed except CustTable data source
0.34, 0.34, 0.38
0.49
5.Customer reasoncode form
0.11, 0.11, 0.12
0.32
What we see in the table above, is that the main thing that is taking time, is the execution of code. The datasources do not affect the user experienced performance in this scenario. The results show that simpler forms with less code have a huge effect of the execution and the cold-start scenario.
WOW! – Other findings.
I have found one area that is affecting heavily the cold startup of forms. That is the office button, that is typically initiated when the form is loading. I tried disabling the office button code, a cold startup of CustTable went from 23s to 5s. And this button is used everywhere.
This “fix” does not seam to have a large effect on warmed up system. But keep in mind that with the one-version strategy and adding extensions we are clearing any cache quite often, that the end-users needs to rebuild on each AOS. As there are thousands of forms, you can multiply the warmup with the number of AOS’s, and you realize why manual warmup take days.
I have informed Microsoft, and hope for a positive response. Let’s continue to dig for code changes that can make the best ERP system even better, and share what you find.
I realized, that when debugging line-by-line, a small gray text pop’s up showing the actual elapsed execution time per statement. This allowed me to find the lines that actually are using a lot of time, by jumping from line to line. The timing here, is from when I did a debug of a cold system. On a warm system it will not show, as then it all is cached.
I’m really proud of finding this, as it have been on my bucket list to find some real good improvements. For more details on the chase for more performance, take a look at the Microsoft Yammer group (If you have access?) https://www.yammer.com/dynamicsaxfee...05410564505600
Старый 09.04.2021, 13:29   #2
Рука-лицо!
Нет, конечно исследование интересное. Автор - пиши еще.
Но, как и водится в подобных исследованиях, главное не выйти на себя или своего начальника.
Подумать страшно, какие вредители затесались в рядах разработчиков!
После спецоперации по нормализации таблиц - стало 12 датасорсов.
Office button на каждой форме развесили, что формы вместо 5ти секунд открываются за 23...
И, как водится в подобных исследованиях в Майкрософте, это автор еще до отчетов не дошел.
Последний раз редактировалось mazzy; 09.04.2021 в 13:32.
Старый 09.04.2021, 14:18   #3
fed is offline
fed
Аватар для fed
2,892 / 5650 (194) ++++++++++
Курт никогда в Микрософте на работал, в отличие от тебя и меня
patrickmouwen: How to Unlock Many Hidden D365 Retail Features! Blog bot DAX Blogs 0 13.05.2020 22:13
kurthatlevik: D365 Importing JSON data the hard way! Blog bot DAX Blogs 0 13.04.2020 16:11
kurthatlevik: D365 and the supply structures in grocery retail industry Blog bot DAX Blogs 0 09.03.2020 00:43
patrickmouwen: D365 Retail APIs Part II: How to know exactly what happens inside D365 Retail Blog bot DAX Blogs 0 14.12.2019 01:17
kurthatlevik: D365 F&O – Fast Track webinars Blog bot DAX Blogs 0 17.01.2019 00:15
Часовой пояс GMT +3, время: 13:48.
