12.05.2016, 14:11 | #1 |
palleagermark: A dynamic strFmt call
Источник: http://www.agermark.com/2016/05/a-dy...rfmt-call.html
============== In the communities a users asked about a way to make a dynamic strFmt call, not knowing the number of parameters up front. With some good critical tests from Levgen Miroshnikov (blog) I think I have managed to write a class method that does that. Regular StrFmt will round decimal value and change the decimal point to whatever fits your windows locale. This method has a parameter allowing you to keep the formatting of decimal values. Here is the code for it: public str dynamicStrFmt( str _expression, container _args = conNull(), boolean _keepRealsDecimals = false) { str ret; Counter counter; str argStr; char argChar; if (_args == conNull()) { return strFmt(_expression); } for (counter = 1; counter
