10.11.2016, 08:14 | #1 |
emeadaxsupport: Financial dimensions that contain the same character as used in the chart of accounts delimiter
Источник: https://blogs.msdn.microsoft.com/axs...nts-delimiter/
============== In Dynamics 365 Operations (AX7) if a financial dimension contains the same character as the chart of accounts delimiter you may experience some instability. The Chart of Accounts delimiter is set on the general ledger parameters and once this is setup the field is greyed out. (Previously this field was located in the system parameters)... Read more Источник: https://blogs.msdn.microsoft.com/axs...nts-delimiter/
