29.09.2016, 11:11 | #1 |
msdn.microsoft.com/nav: Design Pattern: Security – Single Point of Access
Источник: https://blogs.msdn.microsoft.com/nav...int-of-access/
============== Context: Protected data needs to be used. There are many types of entities which might attempt to use the data. Problem: If no standard way of accessing data exists, then each entity might attempt to build its own system for handing the sensitive data. The data access layer might be implemented over and over again... Источник: https://blogs.msdn.microsoft.com/nav...int-of-access/
