Старый 29.04.2017, 02:11   #1
25,475 / 846 (79) +++++++
organicax: Number sequence has been exceeded
Источник: https://organicax.com/2017/04/28/num...been-exceeded/
When you setup AX you will have to configure number sequences in the different modules. Eventual the sequence may run out of numbers in that case you need to create a assign a new sequence. But when the user gets the message that the number sequence has been exceeded it is usually displayed with the recid of the number sequence which is difficult from a business user perspective to relate to the setup.
Now if you know the setup you will likely know the transaction you are doing an the number sequence related to it. If you don’t know the setup then how do you find the number sequence. One trick is that you can use the number sequence list and try to narrow it down using the next number and the largest number. In this case I exported to Excel and use that to help me locate it.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Microsoft Dynamics, Organization model, User tips
organicax: Number sequence wizard Blog bot DAX Blogs 0 02.11.2016 01:11
emeadaxsupport: AX for Retail: Size Barcode setup and creation with number sequence Blog bot DAX Blogs 0 12.02.2015 01:12
emeadaxsupport: Number sequence XXXX has been exceeded Blog bot DAX Blogs 0 29.04.2014 20:11
goshoom: Year in number sequence (AX2012) Blog bot DAX Blogs 0 16.10.2013 16:11
emeadaxsupport: Where is the System ID number sequence used? Will it run out? Blog bot DAX Blogs 0 25.05.2011 00:11
Часовой пояс GMT +3, время: 21:07.
