Старый 03.09.2018, 15:11   #1
25,475 / 846 (79) +++++++
d365technext: Create Customer using X++ D365FO & AX-2012
Источник: http://d365technext.blogspot.com/201...o-ax-2012.html
Following Code will help you to create customer using X++
Default Dimension Class
publicclassDefaultDimesnionHelper
publicstaticDimensionDefaultcreateDefaultDimension(container conAttribute,container attributeValue)
DimensionAttributeValueSetStorage valueSetStorage = newDimensionAttributeValueSetStorage();
DimensionDefault result;
int i;
DimensionAttribute dimensionAttribute;
DimensionAttributeValuedimensionAttributeValue;
// Note that "Item" is not one of the default dimension,
// but DimensionAttributeValueSetStorage will handle it gracefully
container conAttr = conAttribute;
container conValue = attributeValue;
str dimValue;
<div class="MsoNormal">for (i = 1<span style="font-family: Consolas; font-size: 9.5pt;">; i
dynamicsaxse: May-June 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 21.06.2017 00:12
stoneridgesoftware: Part I: Configuring the Dynamics AX 2012 R3 Entity Store Blog bot DAX Blogs 0 27.04.2017 12:11
Dynamics AXBR: AX 2012 – Development I & Development II Blog bot DAX Blogs 1 20.08.2011 13:27
Часовой пояс GMT +3, время: 12:41.
