Старый 15.04.2019, 15:11   #1
25,459 / 846 (79) +++++++
crmtipoftheday: Tip #1252: Creating a Planner task with Flow: wait a minute
Источник: https://crmtipoftheday.com/1252/crea...wait-a-minute/
If you use Microsoft Planner to plan your project tasks, you may want to automate creation of tasks. You can do this with Microsoft Flow.
You will notice that you can’t update fields like the task description when you create a task–this is actually a separate step, called update task details. But if you try to create a Flow that creates a task and immediately tries to update the details, the Flow will fail with a record does not exist error.
To avoid this issue, add a 1 minute delay between creation of the task and update of the details.
Cover photo by unsplash-logoXu Haiwei
crmtipoftheday: Tip #1247: Why you should rename your steps in Flow Blog bot Dynamics CRM: Blogs 0 03.04.2019 17:11
crmtipoftheday: Tip #1205: Local time in Flow using Common Data Service Blog bot Dynamics CRM: Blogs 0 06.12.2018 18:11
crmtipoftheday: Tip #1124: Flow Approvals May Be Exactly What You Need Blog bot Dynamics CRM: Blogs 0 25.06.2018 12:11
atinkerersnotebook: Creating New Customer Notifications for Dynamics 365 for Operations using Flow and the Common Data Service Blog bot DAX Blogs 0 15.12.2016 22:12
Microsoft Dynamics CRM Team Blog: Creating and customizing task flows Blog bot Dynamics CRM: Blogs 0 11.12.2015 04:14
Часовой пояс GMT +3, время: 05:18.
