07.02.2017, 10:11 | #1 |
organicax: Site and warehouse default on RFQ lines
Источник: https://organicax.com/2017/02/06/sit...-on-rfq-lines/
============== If you are setting up an RFQ and have many lines to enter then you might want to consider putting on the site and warehouse on the case to default to the lines. The way the standard form is structured it’s a little hard to see initially because it’s after the lines. Here is a quick overview. AX2012 R3 CU11 Cheers Lachlan Filed under: Procurement and sourcing Источник: https://organicax.com/2017/02/06/sit...-on-rfq-lines/
