Старый 02.03.2016, 08:12   #1
25,475 / 846 (79) +++++++
David Ferguson: Creating a report in X++ code and running
Источник: https://blogs.msdn.microsoft.com/dav...e-and-running/
Here is a small job that demonstrates the main parts of build a report dynamically in X++ and launching it.   static void MakeReportJob(Args _args) {     #AOT     str reportName = ‘aaMakeReport';     tableid custTableId = tablenum(CustTable);     TreeNode reportNode = TreeNode::findNode(#ReportsPath);     Report areport;     ReportDesign design;     ReportAutoDesignSpecs specs;     ReportSection section;...
goshoom: Custom rules for Code Upgrade Tool Blog bot DAX Blogs 0 15.12.2014 02:11
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
mfp: The compare tool–and running X++ code as IL Blog bot DAX Blogs 0 25.06.2012 20:11
David Ferguson: Creating a report in X++ code and running Blog bot DAX Blogs 0 25.05.2010 09:05
emeadaxsupport: Debugging non-interactive X++ code in Dynamics AX 2009 when running on Windows Server 2008 Blog bot DAX Blogs 0 23.09.2009 13:05
Часовой пояс GMT +3, время: 21:08.
