03.11.2016, 03:34 | #1 |
stoneridgesoftware: Changing a Relationship Precedence in Dynamics AX
Источник: https://stoneridgesoftware.com/chang...n-dynamics-ax/
============== Have you ever been in a scenario where a data source has more than one relationship to a table it is being linked to? I have. It wasn’t a problem until I wanted the second relationship to take priority. So the real question is, how to specify what relationship should the table use? In my example, on the InventTable I have multiple relationships defined. Please note though: InventTable.AlcholoManufacturerID_RU == VendTable.AccountNum InventTable.PrimaryVendorId == VendTable.AccountNum On my form: EcoResProductDetailsExtended, I added VendTable as a data source. Well, how does AX know which relationship I want take precedence? By default, AX uses the first one. In this case, the AlcoholManufacturer_RU relationship takes precedence. To change what relationship takes precedence I overloaded the init() method.
VendTable_ds.linkActive(); 3. Third, you must execute the query. vendtable_ds.executeQuery(); </p> It is important to note, this must all be done before the super(). By following these simple steps, you will set a tables relationship precedence on a data source with more than one defined relationship. Your init() method should look like the following. public void init() { vendtable_ds.joinRelation("PrimaryVendTable"); VendTable_ds.linkActive(); vendtable_ds.executeQuery(); super(); } Источник: https://stoneridgesoftware.com/chang...n-dynamics-ax/
Опции темы | Поиск в этой теме |
Опции просмотра | |
