Старый 04.05.2018, 00:23   #1
25,475 / 846 (79) +++++++
powerobjects: Using Virtual Entities with Dynamics 365
Источник: https://www.powerobjects.com/2018/05...-dynamics-365/
Virtual entities allow Microsoft Dynamics 365 users to utilize record information from external data sources and view the information in fields, search results, and even Fetch XML-based reports within Dynamic 365.
A data source record can be configured by a system customizer to create virtual entities without writing code. However, developers can still implement plugins to read data from other sources using the Plug-in Registration tool and the Dynamics 365 SDK.
When defining a virtual entity, the process is like defining a custom entity. With a virtual entity however, you must attach it to a data provider to achieve data retrieval. Specifically, the entity and its fields must be mapped to equivalent data in the external data source. The data provider must offer a GUID and associate it to the external record that represents this entity instance.
Image from Microsoft
Initial Considerations of Virtual Entities:
  • Data is read-only.
  • Only organization-owned entities are supported.
  • Virtual entities cannot be enabled for queues.
  • Field-level security is not supported.
  • A virtual entity cannot represent an activity and do not support business process flows.
For more information on Virtual Entities within Dynamics check out this blog: Dynamics 365 July 2017 Update: Virtual Entities.
Stay tuned for more Dynamics 365 updates. Subscribe to our blog to stay up to date!
powerobjects: Spring Update Webinar Series for Dynamics 365 Blog bot Dynamics CRM: Blogs 0 13.04.2018 21:14
powerobjects: Dynamics 365 as an Application Integration Platform Blog bot Dynamics CRM: Blogs 0 13.04.2018 02:16
powerobjects: Activity View Rollup for Custom Entities in Dynamics 365 Blog bot Dynamics CRM: Blogs 0 27.01.2018 05:56
powerobjects: PowerObjects’ Top 10 Most Popular Blog Posts of 2017 Blog bot Dynamics CRM: Blogs 0 15.12.2017 03:21
Часовой пояс GMT +3, время: 19:40.
