Старый 21.06.2019, 12:12   #1
25,475 / 846 (79) +++++++
alirazazaidi: The batch task you entered is not valid. Enter a different batch task. Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/th...nd-operations/
During development, I got this error, when try to type newly created class that need to be run in batch processing.
That class I manually type because it was not appear in a list new task form inside batch job.
Later I found that I did not implement the canGoBatchJournal() method of RunBaseBatch
After adding following code snippet in my class, it will start to show in batch job task list.
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
Часовой пояс GMT +3, время: 19:17.
