09.02.2017, 17:43 | #1 |
How To control the decimal point in Real values in Dynamics AX365 ?
Hi!!
Could you help me please? I know how to control the decimal point in Real values in Dynamics AX 2009. But Dynamics 365 is totally different. So, To control the decimal point in real value in AX 2009 I do the following : 1- right click on the real field and choose properties 2- go to NoOfDecimals property and put any number you want for example (1 or 2 or 3) This means the numbers after the decimal point example : if the value is 2.31689 if you put 1 the result is 2.3 if you put 2 the result is 2.31 Thanks in advance!! |
