Старый 21.10.2020, 09:13   #1
25,475 / 846 (79) +++++++
dynamicsaxinsight: Chain of command example
Источник: https://dynamicsaxinsight.wordpress....mmand-example/
Purpose:
The purpose of this post is to demonstrate how we can we extend a standard code by using the chain-of-command framework.
Product:
Dynamics 365 for Finance and Operations
Description:
The code below extends the saveAttributeValueSet method of DimensionEntryControl class using the chain-of-command framework.
Code:
[ExtensionOf(classStr(DimensionEntryControl))]final class DimensionEntryControlSXS_Extension{ public DimensionDefault saveAttributeValueSet() { #define.CallerFormName("CustTable") DimensionDefault retCurrentAttrValueSetId; CustTable custTable; retCurrentAttrValueSetId = next saveAttributeValueSet(); if (this.formRun().args().callerName() == #CallerFormName) { FormDataSource dirPartyEntity_ds = this.formRun().dataSource(formDataSourceStr(DirPartyQuickCreateForm,DirPartyEntity)); if (dirPartyEntity_ds) { custTable = dirPartyEntity_ds.cursor(); custTable.DefaultDimension = retCurrentAttrValueSetId; custTable.modifiedField(fieldNum(CustTable, DefaultDimension)); } } return retCurrentAttrValueSetId; }}
dynamicsaxinsight: Budget control for purchase orders Blog bot DAX Blogs 0 03.09.2019 16:11
sertandev: AX7 (D365) Chain of command with example Blog bot DAX Blogs 0 20.03.2018 13:11
sertandev: AX7 (D365) Chain of command with example Blog bot DAX Blogs 1 15.11.2017 19:38
dynamicsaxinsight: AX7/D365/Operations: Create Details Master pattern form Blog bot DAX Blogs 0 14.09.2017 13:11
Часовой пояс GMT +3, время: 22:47.
