19.10.2013, 02:14 | #1 |
emeadaxsupport: AX for Retail 2012: Daisy-chaining Blank Operations
Источник: http://blogs.msdn.com/b/axsupport/ar...perations.aspx
============== In a previous article I showed how easy it is to write a blank operation to add a specific item to a retail transaction: Application.RunOperation(PosisOperations.ItemSale, "0110"); It doesn’t get much simpler than that: a single line of code. Unfortunately there is a limitation to this method: you can only add an item with a quantity of one with its default selling price. I recently had a situation where I wanted to add a negative quantity (to simulate a return) and use a calculated price. I originally thought that I could just run the ItemSale operation and then manipulate the transaction right after it: Application.RunOperation(PosisOperations.ItemSale, "0112");RetailTransaction retailTransaction = posTransaction as RetailTransaction;int iLastLine = Decimal.ToInt32(retailTransaction.NoOfItemLines);SaleLineItem sl = retailTransaction.GetItem(iLastLine);sl.Quantity = -1;sl.Price = 12.34M;retailTransaction.CalcTotals(); Not so much. This doesn’t work because the posTransaction is still a copy of the transaction from before you added the item. There is no visibility into the transaction from after the item was added. I didn’t want to go back to the “old” way of adding an item by manipulating the posTransaction directly. For one thing I would lose the simplicity of the single line of code. In addition there is still a problem where posTransaction doesn’t get converted to a RetailTransaction until after the first item has been added to the transaction. This is a problem if you want to run your blank operation at the very start of a transaction. Calling a Blank Operation from a Blank Operation On a whim I decided to see what would happen if I tried to run a secondblank operation from the first blank operation. I was hoping that the second blank operation would have access to the updated posTransaction with the new item… and it did! When you run a blank operation from a button you can pass in two parameters: OperationId and Parameter. I was worried that this would cause a problem when using the RunOperation to execute the blank operation. Luckily the ExtraInfo parameter works on the this PosisOperations.BlankOperation as well: you can pass in the OperationId and Parameter separated with a semicolon: Application.RunOperation(PosisOperations.BlankOperation, "101; myparam"); This is the equivalent of setting up your button with the same values: With this in mind I broke up the previous code into two operations: 100 to add the item to the transaction, 101 to manipulate: switch (operationInfo.OperationId){ case "100": Application.RunOperation(PosisOperations.ItemSale, "0112"); Application.RunOperation(PosisOperations.BlankOperation, "101"); operationInfo.OperationHandled = true; break; case "101": RetailTransaction retailTransaction = posTransaction as RetailTransaction; int iLastLine = Decimal.ToInt32(retailTransaction.NoOfItemLines); SaleLineItem sl = retailTransaction.GetItem(iLastLine); sl.Quantity = -1; sl.Price = 12.34M; retailTransaction.CalcTotals(); operationInfo.OperationHandled = true; break; default: break;} Testing was easy: I just added a button to operation “100” and gave it a try. As hoped, a return of item 0112 for $12.34 was added to my transaction: A couple of notes on the code:
The practical application of this exercise was to be able to add a service line item to zero out a transaction without using discounts. For instance, if the transaction had a balance of $2.00 I would create a return item of $2.00 to offset. Likewise, a ($3.00) transaction could have the same SKU to create a $3.00 item to zero it out. Hopefully you can find a good real-world use for this little trick as well. Источник: http://blogs.msdn.com/b/axsupport/ar...perations.aspx
