23.03.2017, 11:11 | #1 |
Filter OData entity by enum field.
Источник: https://ievgensaxblog.wordpress.com/...by-enum-field/
============== As you may know, logic apps do not have any triggers available for Dynamics365 for Operations. So we have to use recurrence trigger to read data periodically from a data entity and obviously we want to filter a query. This is pretty straightforward with string or integer fields, but not with enums. Under the hood AX enums are enumeration in OData. For example, I have new entity “RentalInvoices” and I want to filter it by AXCRMTransferStatus field and select only “pending” records. Designer view: Code view: Источник: https://ievgensaxblog.wordpress.com/...by-enum-field/
