22.03.2021, 11:11 | #1 |
ax.docentric: Comment on Configure SharePoint Online integration in D365FO OneBox by Klemen Novak
Источник: https://ax.docentric.com/configure-s.../#comment-2169
============== In reply to Nguyễn Thành Được.Hi Nguyễn,Please install the Connect-MsolService using the following steps:- Go to PowerShell as Administrator on your OneBox machine- Run the command: Install-Module MSOnline- Run the command: Install-Module AzureADAfter the successful installation the command Connect-MsolService should be working as expected.Hope that this helps.Kind regards,Klemen Источник: https://ax.docentric.com/configure-s.../#comment-2169
