Старый 01.04.2017, 02:17   #1
25,475 / 846 (79) +++++++
organicax: Linking BOM lines to a route operation
Источник: https://organicax.com/2017/03/31/lin...ute-operation/
When you have a complex or long running production process you might have a large number of raw materials that could be required at different steps through the production process. So when you setup your BOM and Route you can link the BOM lines to specific operations.
Here is a quick overview.
AX2012 R3 CU11
In a follow-up video we’ll have a look at how to mange the pick lists at difference stages through the operations.
Cheers
Lachlan
Filed under: Production control
organicax: BOM Designer doesn’t show active BOM lines Blog bot DAX Blogs 0 31.03.2017 19:12
organicax: Operation at different steps in a route with different resources Blog bot DAX Blogs 0 30.09.2016 22:13
organicax: BOM Lines Report Blog bot DAX Blogs 0 24.09.2016 03:44
organicax: Copy BOM from lines form to create a new BOM Blog bot DAX Blogs 0 08.04.2016 09:11
Часовой пояс GMT +3, время: 08:29.
