07.02.2015, 18:15 | #1 |
emeadaxsupport: Adding Exchange Rates using the AIF LedgerExchangeRateService Service
Источник: http://blogs.msdn.com/b/axsupport/ar...e-service.aspx
============== The following is a quick example that may help if you need to add an Exchange Rate to an existing Currency Pair in Microsoft Dynamics AX 2012 R3 using the AIF LedgerExchangeRateService service. I ran into a couple snags along the way and finally was able to insert data correctly in AX using the below. When you create the AIF Inbound Port for this service, I recommend to enable logging under the Troubleshooting section in case you need to review the XML that is created. C# Console Application Example The goal in the support case was to add an Exchange Rate to at an already existing Currency Pair (EUR to USD) pair. The code below adds a new Exchange Rate to this existing Currency Pair. using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading.Tasks; using UpdateExchangeRateTester.ERService; namespace UpdateExchangeRateTester { class Program { static void Main(string[] args) { ExchangeRateServiceClient proxy = new ExchangeRateServiceClient(); CallContext cc = new CallContext(); cc.Company = "USMF"; // Call Read First per http://community.dynamics.com/ax/f/33/t/75714.aspx //Criteria will be the From and To for the CurrencyPair (EUR to USD) QueryCriteria qc = new QueryCriteria(); qc.CriteriaElement = new CriteriaElement[2]; qc.CriteriaElement[0] = new CriteriaElement(); qc.CriteriaElement[0].FieldName = "FromCurrencyCode"; qc.CriteriaElement[0].DataSourceName = "CurrencyPair"; qc.CriteriaElement[0].Value1 = "EUR"; qc.CriteriaElement[1] = new CriteriaElement(); qc.CriteriaElement[1].FieldName = "ToCurrencyCode"; qc.CriteriaElement[1].DataSourceName = "CurrencyPair"; qc.CriteriaElement[1].Value1 = "USD"; EntityKey[] keylist = proxy.findKeys(cc, qc); AxdLedgerExchangeRate axdExchangeRate = proxy.read(cc, keylist); foreach (AxdEntity_CurrencyPair currencyPair in axdExchangeRate.CurrencyPair) { currencyPair.action = AxdEnum_AxdEntityAction.update; currencyPair.actionSpecified = true; currencyPair.RateType = null; // do not send in a CurrencyPair RateType on updates //create new exchange rate AxdEntity_ExchangeRate newExchangeRate = new AxdEntity_ExchangeRate(); newExchangeRate.ExchangeRate = 95.60M; //AX value is .95600 newExchangeRate.ExchangeRateSpecified = true; newExchangeRate.ValidFrom = new DateTime(2015, 2, 5); newExchangeRate.ValidFromSpecified = true; newExchangeRate.action = AxdEnum_AxdEntityAction.create; newExchangeRate.actionSpecified = true; currencyPair.ExchangeRate = new AxdEntity_ExchangeRate[1] { newExchangeRate }; } try { proxy.update(cc, keylist, axdExchangeRate); Console.WriteLine("Update Call Complete"); } catch (Exception e) { Console.WriteLine(e.Message); Console.WriteLine("The AxdLedgerExchangeRate was not updated."); } Console.ReadLine(); } } } A couple items I had to do was set the RateType to null on the AxdEntity_CurrencyPair object otherwise I was receiving an AIF Exception on RateType. I also did not send the existing Exchange Rate data in the AxdEntity_ExchangeRate[] collection.I just created a new AxdEntity_ExchangeRate with the action property set to create. The final result looks like what I wanted to achieve with a new Exchange Rate added with correct dates: XML Example This is the XML document that AIF processes from the C# Console Application. You can use this as a starting point if you need to know what the XML schema should look like if you need to create XML for a File Adapter Inbound port. RecId 22565423204 Original USMF 2015-02-05T00:00:00Z http://www.w3.org/2001/XMLSchema-instance"> AsOf http://www.w3.org/2001/XMLSchema-instance"> 911f6653fc2da5d3ce42d69fb95f7269 22565423204 1 EUR USD Average One 95.60 2015-02-05 Источник: http://blogs.msdn.com/b/axsupport/ar...e-service.aspx
