30.12.2010, 15:11 | #1 |
palleagermark: EP pop-up windows with checkboxes
Источник: http://palleagermark.blogspot.com/20...heckboxes.html
============== When building pop-up windows with checkboxes it seems like you can't make the pop-up fields with a checkbox as target. When later reading the value of the pop-up field it always returns “on”. So with checkboxes you must write the value yourself when closing the pop-up window. Here is an example. First some code from my pop-up parent: protected void AddChangeInvoiceBlockScript(SetMenuItemPropertiesEventArgs e, DataSetViewRow row) { AxUrlMenuItem menuItem = new AxUrlMenuItem(BLOCK_DIALOG); if (row != null) { AxTableContext context = AxTableContext.Create(row.GetTableDataKey(row.DataSetView.Metadata.RootDataSource, null)); menuItem.MenuItemContext = context; menuItem.RemoveNavigation = true; e.MenuItem.ClientOnClickScript = this.PopupChangeBlocked.GetOpenPopupEventReference(menuItem); } } And next initialization code and ButtonOK code from my pop-up: protected void Page_Load(object sender, EventArgs e) { if (!IsPostBack) { CheckBoxBlock.Focus(); IAxaptaRecordAdapter ledgerJournalTransRecord; AxBaseWebPart webpart = AxBaseWebPart.GetWebpart(this); if (webpart.ExternalContext != null) { ledgerJournalTransRecord = webpart.ExternalContext.DataKey.GetRecord(this.AxSession); if (ledgerJournalTransRecord != null) if ((int)ledgerJournalTransRecord.GetField(LEDGERJOURNALTRANS_WMAPRBLOC) == 1) CheckBoxBlock.Checked = true; } } } protected void OkButton_Click(object sender, EventArgs e) { try { string fieldValueBlock = CheckBoxBlock.Checked ? BLOCK_YES : BLOCK_NO; // Set the value based on the state of the checkbox popupChild.SetFieldValue("hiddenBlockField", fieldValueBlock); // Calling the script for closing the dialog box this.popupChild.ClosePopup(true, true); } catch (Exception ex) { AxExceptionCategory exceptionCategory; // This returns true if the exception can be handled here if (!AxControlExceptionHandler.TryHandleException(this, ex, out exceptionCategory)) { // The exception was fatal - in this case re-throw the error throw; } } } And finally closing code from my pop-up parent: void PopupChangeBlocked_PopupClosed(object sender, EventArgs e) { // Get the value of the Blocked check box bool block = this.PopupChangeBlocked.GetFieldValue("hiddenBlockField") == "1" ? true : false; // Send the value to the dataset, which will handle the update this.dsWMAprApprovalList.GetDataSet().DataSetRun.AxaptaObjectAdapter.Call("setWMAprBlock", block); // Clear popup values this.PopupChangeBlocked.ClearFieldValues(); // Refresh the grid this.gridWMAprApprovalList.DataBind(); } You can see another example on how to use checkboxes with pop-ups in the TSTimesheetDeleteYesNo User Control. Other resources: Pop-up Windows on MSDN AxPopupParentcontrol on MSDN AxPopupChildControl on MSDN Solution Monkey "Devlopers Cookbook" Источник: http://palleagermark.blogspot.com/20...heckboxes.html
