Старый 11.11.2015, 21:11   #1
25,475 / 846 (79) +++++++
emeadaxsupport: IDMF - How to enable the ByFiscalPeriod template - ShowByFiscalTemplate = True
Источник: http://blogs.msdn.com/b/axsupport/ar...late-true.aspx
Consider a scenario where you are using IDMF 2.0, and you want to work with InventTrans and LedgerTrans data, but you cannot find any archive templates for these tables? It is possible to archive InventTrans and LedgerTrans, but the 'ByFiscalPeriod' template is not enabled by default, and this blog post will show you how to enable it. In the example below, I am working with IDMF 2.0 running on AX 2009, but the AX version I am using is not really relevant.
1. Documentation links
As mentioned in my previous IDMF blog post, the main online documentation can be found here:
// Main Documentation Link:
Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) [AX 2012]
http://technet.microsoft.com/en-us/library/hh378082.aspx
// Installation Guide:
Installation Guide for the Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) [AX 2012]
http://technet.microsoft.com/EN-US/library/hh389759.aspx
// Using IDMF:
Using the Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) [AX 2012]
http://technet.microsoft.com/EN-US/library/hh389763.aspx
// Troubleshooting IDMF:
Troubleshoot the Microsoft Dynamics AX Intelligent Data Management Framework (IDMF) [AX 2012]
https://technet.microsoft.com/EN-US/library/hh389765.aspx
2. Enabling the 'ByFiscalPeriod' template
As mentioned above, you have to actively turn this functionality ON yourself. Until you've done this, you won't see the 'ByFiscalPeriod' template in the list of Archive templates:
You must fully understand the possible consequences of using it before doing so (see the Warning text below, which you can find in the .config file you need to edit):
1) Go to the IDMF install location:
%systemdrive%\Program Files\Microsoft Dynamics AX Intelligent Data Management Framework\AXDataManagementTool.exe.config
e.g.
C:\Program Files\Microsoft Dynamics AX Intelligent Data Management Framework\AXDataManagementTool.exe.config
2) Open the file in a text editor (e.g. Notepad) and search the file for "ShowByFiscalTemplate"
3) Change the value of "ShowByFiscalTemplate" to "true" (the default is "false") and save the file
4) Restart the IDMF console and the 'ByFiscalPeriod' template should appear under Configure / Archive templates
Once you’ve done that, you will see the template in the IDMF console:
You will see a tab for LedgerTrans and one for InventTrans once you’ve selected the ByFiscalPeriod template under Configure / Archive templates:
// LedgerTrans
// InventTrans
3. Summary
You have to actively turn this functionality ON yourself'
Read the WARNING text in the .config file.
The file you need to edit is called 'AXDataManagementTool.exe.config'.
The 'key' you need to change the 'value' of (from 'false' to 'true') is called 'ShowByFiscalTemplate'.
You need to restart the IDMF console for the changes to take effect.
You will find the 'ByFiscalPeriod' template under 'Configure / Archive templates' when you've enabled it.
emeadaxsupport: IDMF - How to troubleshoot job status issues like Last run result = Error Blog bot DAX Blogs 10 04.11.2015 16:09
ошибка в AIF syl DAX: Программирование 14 20.08.2015 15:25
emeadaxsupport: How to: Automatically assigning a Load template ID to a load in Microsoft Dynamics AX 2012 R3 Blog bot DAX Blogs 0 31.03.2015 21:12
emeadaxsupport: How to enable “Conditions” for Retail jobs in AX 2012 R2 Blog bot DAX Blogs 2 22.07.2013 10:55
emeadaxsupport: AX 2012 Retail: How to enable tracing in AX 2012 Retail Blog bot DAX Blogs 0 07.08.2012 15:11
Часовой пояс GMT +3, время: 10:34.
