26.12.2017, 19:11 | #1 |
a33ik: SysOperation job template
Источник: http://daxonline.org/1596-sysoperati...-template.html
============== Contract with query: /// /// The SOLCustMarketingClearDataContract contract for the job to clear customer marketing information./// [DataContractAttribute]class SOLCustMarketingClearDataContract{ str encodedQuery; [DataMemberAttribute, AifQueryTypeAttribute('_encodedQuery', queryStr(SOLCustMarketingQuery))] public str parmQuery(str _encodedQuery = encodedQuery) { encodedQuery = _encodedQuery; return encodedQuery; }} Controller: /// /// The SOLCustMarketingClearController controller for the job to clear customer marketing information./// class SOLCustMarketingClearController extends SysOperationServiceController{ public ClassDescription caption() { ClassDescription ret; ret = "@SOLMod:ClearUnregisteredEmailAddresses"; return ret; } public LabelType parmDialogCaption(LabelType _dialogCaption = "") { LabelType caption; caption = "@SOLMod:ClearUnregisteredEmailAddresses"; return caption; } public static SOLCustMarketingClearController construct() { return new SOLCustMarketingClearController(); } public void getFromDialog() { //FormComboBoxControl mainAccountControl; //DialogForm theDialogForm; SOLCustMarketingClearDataContract contract; //theDialogForm = this.dialog().dialogForm(); super(); //mainAccountControl = theDialogForm.runControl(#MainAccount); contract = this.getDataContractObject(classStr(SOLCustMarketingClearDataContract)); if (contract) { // Set the values in data contract //contract.parmMainAccount(mainAccountControl.text()); } } public static void main(Args args) { SOLCustMarketingClearController controller; identifierName className; identifierName methodName; SysOperationExecutionMode executionMode; [className, methodName, executionMode] = SysOperationServiceController::parseServiceInfo(args); controller = new SOLCustMarketingClearController(className, methodName, executionMode); if (controller.prompt()) { controller.run(); } }} Service: /// /// The SOLCustMarketingClearService the job to clear customer marketing information./// class SOLCustMarketingClearService{ /// /// Clears unregistered customer email addresses /// /// /// Job contract, contains query of records, which should be deleted /// public void clearCustMarketing(SOLCustMarketingClearDataContract _contract) { Query q = new Query(SysOperationHelper::base64Decode(_contract.parmQuery())); QueryRun qr= new QueryRun(q); SOLCustMarketing custMarketing; int recordsDeleted; ttsbegin; while (qr.next()) { custMarketing = qr.get(tableNum(SOLCustMarketing)); custMarketing.selectForUpdate(true); custMarketing.delete(); recordsDeleted++; } info(strfmt("@SOLMod:NonRegCustRecordsDeleted", recordsDeleted)); ttscommit; }} Action Menu Item: Enum Type Parameter: SysOperationExecutionMode Enum Parameter: Synchronous Object Type: Class Object: SOLCustMarketingClearController (controller class) Parameters: SOLCustMarketingClearService.clearCustMarketing (service static method to run) Источник: http://daxonline.org/1596-sysoperati...-template.html |
Опции темы | Поиск в этой теме |
Опции просмотра | |
