Старый 30.04.2016, 03:35   #1
25,475 / 846 (79) +++++++
organicax: Printing a barcode for testing
Источник: https://organicax.com/2016/04/29/pri...e-for-testing/
If you are just starting out with AX and wanted to play with the warehouse mobile device and do some testing. If you don’t have any barcode label software and a special label printer but you have a decent laser printer  a simple work around it to use a site that produces a barcode for you. One example is https://www.barcodesinc.com/generator/index.php
It has a handy function to put in some text and then give you an image which you can then print. So if you have a couple of barcodes you want to print to test out scanning then this is good enough.
Here is a quick overview.
Cheers
Lachlan
Filed under: Warehouse management
DynamicsAxSCM: Barcode Scanning in the Mobile Device Blog bot DAX Blogs 0 30.04.2015 18:12
emeadaxsupport: AX for Retail Barcode Font Printing Issues Blog bot DAX Blogs 0 09.12.2014 01:12
dax-lessons: Display Barcode in SSRS report [Dynamics AX 2012, X++] Blog bot DAX Blogs 0 15.05.2012 18:11
emeadaxsupport: AX for Retail: Printing Receipts with Windows Drivers Blog bot DAX Blogs 0 25.01.2012 10:11
Часовой пояс GMT +3, время: 04:15.
