Старый 01.10.2017, 16:14   #1
25,475 / 846 (79) +++++++
dynamicsnavax: First look at Azure Functions
Источник: http://dynamicsnavax.blogspot.com/20...functions.html
Azure Functions allows you to write code that can be triggered by an event or timer. You don’t need a machine to run it on. All the computing runs on the Azure cloud ie sevrverless computing.
Below is a quick walk through. Keep in mind Microsoft has great documentation on their site. Just google it.
In this post I will put a simple walkthrough. Save you from the information overload.
Make sure you are using Visual Studio 2017.
Create a project of type “Azure Function”
Give it a minute to resolve the NuGet package. You will see a warning icon and watch it disappear by it self.
Once its done. Right click and Add item.
Select the type of function. The easiest to do is the Http trigger.
This will create a class with some sample code.
When you run it, it will run a local instance.
Navigate to the URL and watch it run.
There are many applications in the Dynamics space. Hopefully next time I can cover some Dynamics scenarios.
Navigate Into Success: Invoking Azure Functions from AL recording available Blog bot NAV: Blogs 1 10.12.2019 08:58
dynamicsnavax: Hybrid connection - Web Api App for AX 2012 to Azure-part 4 Blog bot DAX Blogs 0 14.09.2017 13:11
Navigate Into Success: Webinar: Invoking Azure Functions from AL in Visual Studio Code Blog bot NAV: Blogs 0 25.08.2017 00:12
Navigate Into Success: Invoking Azure Functions from AL Blog bot NAV: Blogs 0 08.06.2017 15:11
Часовой пояс GMT +3, время: 16:05.
