28.11.2018, 03:42 | #1 |
lcs: Issues when syncing to BPM using a custom Azure DevOps (VSTS) process template
Источник: https://blogs.msdn.microsoft.com/lcs...cess-template/
============== When setting up your Azure DevOps (VSTS) project in Lifecycle Services (LCS), if you use an inherited process template with custom fields, you may receive the following warning message: "The selected VSTS project is based on a custom process template. Custom process templates are not supported and may cause errors when synchronizing Business Process Modeler... Источник: https://blogs.msdn.microsoft.com/lcs...cess-template/
