Старый 28.08.2022, 07:46   #1
25,475 / 846 (79) +++++++
ievgensaxblog: MSDyn365FO. Missing custom financial dimension.
Источник: https://ievgensaxblog.wordpress.com/...ial-dimension/
If you want to make a table (standard or a new one) usable as a Financial dimension there is a step by step guide on docs Make backing tables consumable as financial dimensions – Finance & Operations | Dynamics 365 | Microsoft Docs
However, there is a gotcha, it won’t work if view’s name is too long (longer than 40 characters).
The issue lies with DimensionEnabledTypeCollection::getDimensionEnabledTypeCollection method, where it tries to select a record from SqlDictionary table by viewName
Under the hood it will generate a SQL statement like
(@P1 nvarchar(25))SELECT TOP 1 T1.RECID, T1.RECID FROM SQLDICTIONARY T1 WHERE( T1.NAME = @P1)
And @P1 parameter’s length would be different from time to time, causing truncation of the view’s name.
There is a good yammer thread discussing this issue Yammer
So, the name is truncated, it cannot be found, and it throws an error:
The SQL view definition for %1 is deployed as a code package but has not been synchronized with the database. As it is currently used by one or more financial dimensions, the database must be synchronized to the code deployment.
However, you won’t see the error. To trigger it you need to do full DB sync or at least sync a view that uses this method, for example, FinancialDimensionValueEntityExistingListView. You won’t catch it during a build either because we all use Microsoft-hosted agents that do not do sync anymore. But what about a Tier-2 deployment? It does DB sync, however, it won’t fail either. It will be successfully deployed, and next error will be logged into the deployment logs:
Infolog diagnostic message: ‘The SQL view definition for MyView is deployed as a code package but has not been synchronized with the database. As it is currently used by one or more financial dimensions, the database must be synchronized to the code deployment.’ on category ‘Error’.
But who would ever check the logs for a successful deployment?!
ievgensaxblog: MSDyn365FO. How-to extend product dimension lookup to add dimension description. Blog bot DAX Blogs 12 01.07.2019 12:13
stoneridgesoftware: Create Custom Dialog on Form with Customer Lookup for a Specific Financial Dimension in D365 FinOps Blog bot DAX Blogs 0 11.04.2019 20:12
alirazazaidi: Custom financial Dimension shows in lookup D365 for Finance and operations Blog bot DAX Blogs 0 14.09.2017 13:11
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 13:45.
