Старый 10.04.2017, 13:11   #1
25,475 / 846 (79) +++++++
organicax: Quality association for production route operation
Источник: https://organicax.com/2017/04/09/qua...ute-operation/
In an earlier post we had a look at setting up an quality association to a production order. There is often a need to do quality checks through a production process. So it would be helpful to trigger a quality order at a route operation.
You can configure the quality association at a route operation which gives you some options to trigger it based on a specific resource or type of operation.
Here is a quick overview.
AX2012 R3 CU11
Cheers
Lachlan
Filed under: Production control, Quality control
organicax: Quality association to a production order Blog bot DAX Blogs 0 08.04.2017 19:11
organicax: Operation relations and the production order route Blog bot DAX Blogs 0 17.10.2016 23:11
organicax: Deleting a route step and the effect on operation relationships Blog bot DAX Blogs 0 16.10.2016 19:16
organicax: Operation at different steps in a route with different resources Blog bot DAX Blogs 0 30.09.2016 22:13
dynamicsaxtraining: Quality management Blog bot DAX Blogs 0 12.02.2011 00:11
Часовой пояс GMT +3, время: 15:32.
