21.01.2019, 06:16 | #1 |
alirazazaidi: Custom designs for business documents- Issue Original report was running instead customized, Dynamics 365 for finance and operations
Источник: https://www.tech.alirazazaidi.com/cu...nd-operations/
============== I did some customization in Business Document or some places these reports are called control document. In classic Ax 2012 we overlay and a lot of efforts saves. But In D365 use extension, which is more powerful feature. With help of a following article I did customization at least 3 to 4 reports and these reports works fine. https://docs.microsoft.com/en-us/dyn...-business-docs But In one case. It did not work, the required report designer did not show in Setup > Forms > Form setup. Click Print Management . And original report with design run instead of custom design. I tried on multiple environment, but issue sustain. By adding following code snippet in my Extended Controller class will resolve the issue. It works for me. protected void outputReport()Источник: https://www.tech.alirazazaidi.com/cu...nd-operations/
